Ir para o conteúdo principal
Turtle Beach Ear Force XO One Adapter Buttons Replacement
O que você precisa
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: passo 1, imagem 1 %32
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 2, imagem 1 %32
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 3, imagem 1 %32 Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 3, imagem 2 %32 Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 3, imagem 3 %32
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 4, imagem 1 %32
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Joseph Lane
Membro desde: 10/27/15
128 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-1, Shastany Fall 2015 Membro de UMass Dartmouth, Team 3-1, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,566
