Ir para o conteúdo principal
Turtle Beach Ear Force X12 Slide Adjustment Replacement
O que você precisa
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: passo 1, imagem 1 %32
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: passo 2, imagem 1 %32 Turtle Beach Ear Force X12 Slide Adjustment Replacement: passo 2, imagem 2 %32 Turtle Beach Ear Force X12 Slide Adjustment Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
Conclusão
Katha Patel
Membro desde: 10/02/17
218 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Thompson Fall 2017 Membro de USF Tampa, Team S1-G3, Thompson Fall 2017
USFT-THOMPSON-F17S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 518
