Introdução
Use this guide to replace the battery in your Turtle Beach Ear Force Stealth 500P headphones.
O que você precisa
Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
Work circularly until removed.
Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
10 outras pessoas executaram este guia.
3 comentários
Where can I get a replacement battery?
You can look on Ebay or Amazon. You can find it by searching the model number: ( FT603048P )
The costs are like $20-$30.
If you look on Ebay under: ( 3.7v 603048 ), you can get the same battery without the connector for like $5.
hey i have a question, how i can repair the mute button? It does not work.
