Introdução
This guide will take you step by step through the process of replacing the battery in the Palm Tungsten T3.
O que você precisa
Remove the two Phillips #00 screws on either side of the device, on the sliding panel.
10 outras pessoas executaram este guia.
Um comentário
The only thing I would add is before replacing the battery, be sure to backup your device since disconnecting the battery will do a total reset.
