Ir para o conteúdo principal
Troubleshooting & Repairing the Nissan Xterra Air Conditioning
O que você precisa
  1. Troubleshooting & Repairing the Nissan Xterra Air Conditioning, Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 1, imagem 1 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning, Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 1, imagem 2 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning, Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 1, imagem 3 %32
    • The Thermistor connector is located below the glove box. You can see the white connector hanging out from under the dash.
    • The purpose of the Thermistor is to keep the Evaporator from freezing. It does this by measuring the temperature and turning off the Compressor when the Evaporator gets below approx. 40 degrees F allowing the Evaporator to defrost.
    • Locate your Air Conditioning Compressor. The clutch is the center area. If the clutch is engaged the center area will be turning. It will be turned off by the Thermistor to prevent the Evaporator from Freezing.
    • Here are the tools that you'll need to complete this guide.
  2. Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 2, imagem 1 %32
    • Test the thermistor by turning the Engine ON and the Air Conditioner ON.
    • Using a Voltmeter (set to DC Volts), the Green/Orange wire will have battery voltage (around 13.5vdc) from fuse #29 in the under hood fuse box.
    • The Blue wire will have battery ground from the AC control assembly.
    • The most important wire is the Blue/Black wire. The Voltmeter will show less than .5 volts with the thermistor on (temperature above 45 degrees F). It will show a nominal 4-5 volts with the thermistor off (temperature below 40 degrees F).
    • During inital operation, the temperature at the evaporator will be above 45 degrees and the Voltmeter should read less than .5 volts. When the temperature of the evaporator is below 40 degrees F, the Voltmeter will read 4-5 volts which turns the Air Conditioner Compressor OFF. This keeps the Evaporator from freezing.
    • If your Thermistor is reading 4-5 volts when you first turn the AC on then your Thermistor is defective and needs to be replaced.
    Hello good day. I tested my ac thermistor the blue/black wire reading is above 0.5v when I just turn on the a/c. Is the thermistor bad already? Thanks
    type1028 - Responder
    ,if I unplug the bad coupling and plug up the new one will the unit work then before take it apart???
    Jimmy Parker - Responder
  3. Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 3, imagem 1 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 3, imagem 2 %32
    • Replacing the Thermistor requires removal of the glove box.
    • Remove the four upper screws and the two lower screws as indicated.
  4. Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 4, imagem 1 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 4, imagem 2 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 4, imagem 3 %32
    • Using a philips screwdriver, remove three screws. (as indicated by the orange circles)
    • Using a 10mm socket, remove four bolts (as indicated by the blue squares) The two on the right are easy to see but the two on the left are difficult to see and are behind structure.
  5. Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 5, imagem 1 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 5, imagem 2 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 5, imagem 3 %32
    • Here's were it can get tricky. Of course the correct way to replace this is to completely evacuate the system and remove the evaporator but with a little ingenuity you can have it replaced in 10 minutes.
    • Open the evaporate shell by splitting the halves. I used a spring clamp, backwards, to help me hold the halves open.
    • Using a long pair of needle nose pliers, gently work the Thermistor out of the evaporate fins.
  6. Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 6, imagem 1 %32 Troubleshooting & Repairing the Nissan Xterra Air Conditioning: passo 6, imagem 2 %32
    • I purchased a new Thermistor for $52 at the dealership. Install the new thermistor by using the Long Needle Nose Pliers to insert into the evaporator fins.
    • Removing the connector from the bracket was difficult and I broke the bracket. I was happy to see that a new a mounting bracket came with the new thermistor. You will need a small sheet metal screw to attach the mounting bracket in a hole next to the existing mounting bracket. They provided a hole for you to mount the new bracket. ( I guess they al
    Be careful when installing the new one, the attachment arm can break fairly easy if you force it.
    Tom - Responder
Conclusão
To reassemble your Air Conditioning System, follow these instructions in reverse order.
33 outras pessoas executaram este guia.
Doug Layne
Membro desde: 06/21/12
1.195 Reputação
Autoria de 1 guia
26 comentários
Excellent information. My 2003 Xterra was acting up with the AC compressor kicking off and on when the vehicle got up to temperature. One mechanic told me the compressor was knocking and ready to fail. I found out that it was simply overcharged with Freon after a high pressure AC hose replacement. It has worked fine for two years now after getting the Freon right.
Glenn - Responder
Article by Doug Layne was the answer to my 2000 Nissan Frontier Crew Cab. The Thermo Amplifier was the cause of my problem. A/C works like new. Also make sure you clean inside the unit. I have no idea how so much dirt got into the unit. Must be poor design.
Thanks Doug from another Doug
Doug Wacha - Responder
What was yours doing and what did you do to fix it.I just got mine 01 and the compressor is working but not cooling much.please help.
jbegleybuild -
What was yours doing.my compressor is working and the garage charged it but not getting cold.they said they thouhht it was the expansion valve.what do you think
jbegleybuild -
In step 6, part of the sentence is cut off, what should it say: "They provided a hole for you to mount the new bracket. ( I guess they al"
Karen Strong - Responder
This info was awesome! I was having the same problem ( cold air and when you shut the car off it might not come back for 10 - 15 min after restart. got an ac thermistor amplifier and did the install as shown ( great pictures and info ) and problem is fixed. Thanks for sharing . Wife drives the xterra and is very happy :) :)
rkcarcare - Responder
What if you don't pick up any volts from the blue/black wire?
Eddie luna - Responder
My 2003 Xterra was having same issue. Replacing thermistor was the fix but 2003 Xterra used a two wire component instead of three. Nissan PN 27723-8J000.
ben1542 - Responder
My 2002 Xterra AC worked intermittently the past two summers. It would often start fine in the morning but not work after a couple of stops. I could hear the solinoid clicking but just couldn't get the cold air to come on again. A mechanic said it needed a new clutch/compressor unit. Fortunately my son was able to replace the thermistor using your instructions. It works like new now - and at a savings of at least $600. If I'd gone to the expense of replacing the unit, the problem would still exist. Thank you for saving us a bundle!
Connie - Responder
2004 frontier replace all of my a/c component holds vacuum got the freon ,check all of the relays and still the compressor still no engaging comes on sometimes please help.
amartell79 - Responder
How do you release the thermistor plug from under the dash? it seems like it is screwed in place and doesn't want to release from the dash
tom - Responder
If you were to recharge a ac using a ac recharge on a 2013 xterra what port would you use the low
ac port or the evap test booster?
Kyle - Responder
Where is the acc compress located on a 2003 Nissan xterra
onealpat.5 - Responder
I think it is the same as my 2000 Frontier. Looking at the engine its on the right side.
The pulley looks different that the others because of the clutch.
Russ -
What if you have 12 volts on the blue and black wire? I replaced my thermostor and still same issue. The new one looks different though.
Russ - Responder
Worked on my Nissan 2000 Xterra,,, had tried other stuff with no success ,
morajuan80@gmail.com - Responder
So far this seems to have fixed my intermittent cooling issue on my 2002 Frontier.
I had to take out the middle parts of the dash as well around the dials, I needed more room to work. It’s a tight area to work in.
even so, I broke the connecting arm on my first attempt of putting the new one in. Takes patience, and don’t force it. The second attempt went much better. $30 part at O'Reilly.
thanks for posting this! Nicely done
Tom - Responder
mingalarpar friends
mg myo - Responder
Do you think this is too ambitious for an amiture???
smudgeandnatthecat - Responder
I have a 2001 Nissan Xterra that is having the same issue. The compressor clutch kicking off/ on intermittently. Then, Stays off & starts blowing just warm air. It has a brand new Condenser, Compressor, Low Pressure Line. And, Full of Freon. So, I ordered a new Thermistor(Nissan PN: 27675-9Z000). I ordered from Amazon. I hope it's the correct one. And, That it fixes the issue I'm having. Because, This Oklahoma Heat & Humidity is horrible!!
carver_jm1980 - Responder
Thank You! Great Information!
iamago - Responder
In step 2 testing with a multimeter do you only need to stick the positive probe into the wire terminals? Thanks in advance!
dkgoodman - Responder
The issue i am having is the a.c. will blow cold air then hot air… and after a few minutes cold again..
any advise.
manny ramirez - Responder
With your guidance I got the part from Carid.com <$30. Used the reverse clamps as suggested! Wrapped my left wrist and top of hand with blue painters tape to reduce chance of getting cut and it worked great! Thank you, my AC is now blowing COLD!!!
Victor Kan - Responder
This is very good detail process specifically about measuring voltage. I was able to get part replaced and AC is working now. Thank you
Nimpat - Responder
Hey guys! I'm having overheating only when I cut on the AC. Just checked thermistor with multimeter and it's faulty. Will replacing it help my truck to stop overheating and leaking from the condenser?
Tyler Mosteller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 64
Últimos 30 dias: 224
Duração total: 175,031
