Ir para o conteúdo principal
Tristar Handmixer Gears Replacement
O que você precisa
  1. Tristar Handmixer Gears Replacement, Gears: passo 1, imagem 1 %32 Tristar Handmixer Gears Replacement, Gears: passo 1, imagem 2 %32 Tristar Handmixer Gears Replacement, Gears: passo 1, imagem 3 %32
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: passo 2, imagem 1 %32 Tristar Handmixer Gears Replacement: passo 2, imagem 2 %32 Tristar Handmixer Gears Replacement: passo 2, imagem 3 %32
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: passo 3, imagem 1 %32 Tristar Handmixer Gears Replacement: passo 3, imagem 2 %32 Tristar Handmixer Gears Replacement: passo 3, imagem 3 %32
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: passo 4, imagem 1 %32 Tristar Handmixer Gears Replacement: passo 4, imagem 2 %32
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: passo 5, imagem 1 %32
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
where can I get replacement gears from?
lanz - Responder
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 1,491
