Ir para o conteúdo principal
Trio Stealth-Mini Screen Replacement
O que você precisa
  1. Trio Stealth-Mini Screen Replacement, Battery: passo 1, imagem 1 %32 Trio Stealth-Mini Screen Replacement, Battery: passo 1, imagem 2 %32
    • Locate the indentation at the bottom of the device.
  2. Trio Stealth-Mini Screen Replacement: passo 2, imagem 1 %32 Trio Stealth-Mini Screen Replacement: passo 2, imagem 2 %32 Trio Stealth-Mini Screen Replacement: passo 2, imagem 3 %32
    • Pull on the indentation and take off the casing of the device.
  3. Trio Stealth-Mini Screen Replacement: passo 3, imagem 1 %32 Trio Stealth-Mini Screen Replacement: passo 3, imagem 2 %32
    • Remove the faulty battery and insert a replacement in its slot.
  4. Trio Stealth-Mini Screen Replacement, Screen: passo 4, imagem 1 %32
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Trio Stealth-Mini Screen Replacement: passo 5, imagem 1 %32
    • Remove inner casing exposing the motherboard.
  6. Trio Stealth-Mini Screen Replacement: passo 6, imagem 1 %32 Trio Stealth-Mini Screen Replacement: passo 6, imagem 2 %32
    • Remove speakers by peeling back yelllow tape.
  7. Trio Stealth-Mini Screen Replacement: passo 7, imagem 1 %32
    • Remove ribbon cable on top of motherboard.
  8. Trio Stealth-Mini Screen Replacement: passo 8, imagem 1 %32
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  9. Trio Stealth-Mini Screen Replacement: passo 9, imagem 1 %32
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  10. Trio Stealth-Mini Screen Replacement: passo 10, imagem 1 %32
    • Verify that all screws are detached from screen.
  11. Trio Stealth-Mini Screen Replacement: passo 11, imagem 1 %32
    • Detach screen from main assembly.
Conclusão
Stewart Jenkins
Membro desde: 03/26/18
207 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Harley Spring 2018 Membro de IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
Membros da 7
Autoria de 6 guias
Um comentário
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 224
