Introdução
Tablet screens often get damaged, this guide will walk a user through the steps of replacing a damaged screen. It is important to be careful about damaging parts, as most pieces are fragile.
Peças
Não são necessárias peças.
  1. Locate the indentation at the bottom of the device. Locate the indentation at the bottom of the device.
    • Locate the indentation at the bottom of the device.
  2. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device.
    • Pull on the indentation and take off the casing of the device.
  3. Remove the faulty battery and insert a replacement in its slot. Remove the faulty battery and insert a replacement in its slot.
    • Remove the faulty battery and insert a replacement in its slot.
  4. Remove the six 2.4 mm, Phillips #0 screws circled in the image.
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  6. Remove inner casing exposing the motherboard.
    • Remove inner casing exposing the motherboard.
  7. Remove speakers by peeling back yelllow tape. Remove speakers by peeling back yelllow tape.
    • Remove speakers by peeling back yelllow tape.
  8. Remove ribbon cable on top of motherboard.
    • Remove ribbon cable on top of motherboard.
  9. Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  10. Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  11. Verify that all screws are detached from screen.
    • Verify that all screws are detached from screen.
  12. Detach screen from main assembly.
    • Detach screen from main assembly.
Conclusão
Stewart Jenkins
207 reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Harley Spring 2018 Membro de IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Membros
4 Guides authored
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 75
