Introdução
A common issue with smart devices is a faulty battery. This guide goes through the steps needed to replace the battery of a Trio Stealth-Mini.
  1. Locate the indentation at the bottom of the device. Locate the indentation at the bottom of the device.
    • Locate the indentation at the bottom of the device.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device.
    • Pull on the indentation and take off the casing of the device.
  4. Remove the faulty battery and insert a replacement in its slot. Remove the faulty battery and insert a replacement in its slot.
    • Remove the faulty battery and insert a replacement in its slot.
Conclusão
Damon Myers
97 reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Harley Spring 2018 Membro de IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Membros
4 Guides authored
Where can I get a battery for this device
Rakeida - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Todo: 67
