Ir para o conteúdo principal
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
O que você precisa
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: passo 1, imagem 1 %32
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: passo 2, imagem 1 %32
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: passo 3, imagem 1 %32
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: passo 5, imagem 1 %32
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Conclusão
Daniel Coleman
Membro desde: 10/29/15
643 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-4, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 418
