O que você precisa
Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
While holding the mother board down, slowly remove the battery from tape on the back of the screen.
Peel the black tape located on the left side of the motherboard.
Peel the orange tape holding down the wire coming from the bottom left side of the motherboard.
The screws to remove the motherboard are located on the top hand side towards the charging port.
To reveal the screws, peel of the thin yellow film that covers the whole motherboard just until the screws are accessible.
Remove the three 1.2mm Phillips #1 screws using the screwdriver in your 26 Bit Driver Kit.
