Ir para o conteúdo principal
Trio STEALTH-9 Speaker Replacement
O que você precisa
  1. Trio STEALTH-9 Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Speaker Replacement: passo 2, imagem 1 %32
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Speaker Replacement: passo 3, imagem 1 %32
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Speaker Replacement: passo 4, imagem 1 %32
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
  5. Trio STEALTH-9 Speaker Replacement, Speaker: passo 5, imagem 1 %32
    • Slowly remove the electrical tape holding down the Speaker wires.
  6. Trio STEALTH-9 Speaker Replacement: passo 6, imagem 1 %32 Trio STEALTH-9 Speaker Replacement: passo 6, imagem 2 %32
    • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
  7. Trio STEALTH-9 Speaker Replacement: passo 7, imagem 1 %32
    • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
    • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
Conclusão
To reassemble your device, follow these instructions in reverse order, making sure to be careful with your wiring leads and soldering work.
[deleted]
Membro desde: 01/29/15
415 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 146
