Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use your thumbs to slide up and off the small SD card case.
Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
Ferramenta utilizada nesse passo:Plastic Cards$2.99-
Use the plastic card to pry the battery away from the device.
Peel off the battery from the device and set aside.
Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
Disconnect the silver tape that attaches the motherboard to the metal panel.
Disconnect the ribbon from the bottom portion of the motherboard.
Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
Located towards the bottom, carefully remove the yellow film.
Gently disconnect the small ribbon found underneath the film.
Lifting up the motherboard, disconnect the second ribbon found underneath.
Remove the speaker and bottom portion of the motherboard.
Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
Use the plastic card to separate the metal panel from the screen component.
Use the plastic card to separate screen component from front panel.
Use the plastic card to separate the glass from the front panel.
