Ir para o conteúdo principal
Trio AXS 3G Camera Replacement
O que você precisa
  1. Trio AXS 3G Camera Replacement, Back Case: passo 1, imagem 1 %32
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Camera Replacement: passo 2, imagem 1 %32 Trio AXS 3G Camera Replacement: passo 2, imagem 2 %32
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Camera Replacement: passo 3, imagem 1 %32
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Camera Replacement, Camera: passo 4, imagem 1 %32 Trio AXS 3G Camera Replacement, Camera: passo 4, imagem 2 %32
    • Unscrew 5 #000 4 mm and 3 mm screws around the strip.
  5. Trio AXS 3G Camera Replacement: passo 5, imagem 1 %32
    • Undo the tape on top of the connector from the camera to motherboard.
  6. Trio AXS 3G Camera Replacement: passo 6, imagem 1 %32
    • Slightly lift up the motherboard.
  7. Trio AXS 3G Camera Replacement: passo 7, imagem 1 %32 Trio AXS 3G Camera Replacement: passo 7, imagem 2 %32
    • Disconnect the camera from the motherboard on the topside and pull the camera strip out.
Conclusão
Um comentário
Where can I get the camera?
Amanda Springsteen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 158
