Ir para o conteúdo principal
Triace A310 Disk Brake Replacement
O que você precisa
  1. Triace A310 Disk Brake Replacement, Tire: passo 1, imagem 1 %32
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: passo 2, imagem 1 %32 Triace A310 Disk Brake Replacement: passo 2, imagem 2 %32
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: passo 3, imagem 1 %32 Triace A310 Disk Brake Replacement: passo 3, imagem 2 %32
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: passo 4, imagem 1 %32
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: passo 5, imagem 1 %32 Triace A310 Disk Brake Replacement: passo 5, imagem 2 %32 Triace A310 Disk Brake Replacement: passo 5, imagem 3 %32
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: passo 6, imagem 1 %32 Triace A310 Disk Brake Replacement: passo 6, imagem 2 %32
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Conclusão
Daniel
Membro desde: 01/27/14
222 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 1-37, Maness Winter 2014 Membro de Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 617
