Ir para o conteúdo principal
Triace A310 Brake Cable Replacement
O que você precisa
  1. Triace A310 Brake Cable Replacement, Brake Cable: passo 1, imagem 1 %32 Triace A310 Brake Cable Replacement, Brake Cable: passo 1, imagem 2 %32
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: passo 2, imagem 1 %32 Triace A310 Brake Cable Replacement: passo 2, imagem 2 %32 Triace A310 Brake Cable Replacement: passo 2, imagem 3 %32
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: passo 3, imagem 1 %32 Triace A310 Brake Cable Replacement: passo 3, imagem 2 %32
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: passo 4, imagem 1 %32 Triace A310 Brake Cable Replacement: passo 4, imagem 2 %32 Triace A310 Brake Cable Replacement: passo 4, imagem 3 %32
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: passo 5, imagem 1 %32 Triace A310 Brake Cable Replacement: passo 5, imagem 2 %32 Triace A310 Brake Cable Replacement: passo 5, imagem 3 %32
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
Conclusão
To place the new cable, follow these instructions in reverse order.
Ben Hartinger
Membro desde: 01/27/14
340 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-37, Maness Winter 2014 Membro de Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 327
