Ir para o conteúdo principal
Trek 820 Tail Light Mounting Bracket Replacement
O que você precisa
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: passo 1, imagem 1 %32
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: passo 2, imagem 1 %32
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: passo 3, imagem 1 %32 Trek 820 Tail Light Mounting Bracket Replacement: passo 3, imagem 2 %32
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: passo 4, imagem 1 %32 Trek 820 Tail Light Mounting Bracket Replacement: passo 4, imagem 2 %32
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Conclusão
Equipe
Cal Poly, Team 1-1, Propen Fall 2012 Membro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,140
