Ir para o conteúdo principal
Trek 820 Light Mount Replacement
O que você precisa
  1. Trek 820 Light Mount Replacement, Light Mount: passo 1, imagem 1 %32 Trek 820 Light Mount Replacement, Light Mount: passo 1, imagem 2 %32
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: passo 2, imagem 1 %32
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: passo 3, imagem 1 %32
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: passo 4, imagem 1 %32
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: passo 5, imagem 1 %32 Trek 820 Light Mount Replacement: passo 5, imagem 2 %32
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
Conclusão
Now you have a light mount ready for safer night rides on your Trek bicycle!
Equipe
Cal Poly, Team 1-1, Propen Fall 2012 Membro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 866
