Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
Remove the handlebar by lifting vertically away from the frame.
Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
