Ir para o conteúdo principal
Trek 820 Handlebars Replacement
O que você precisa
  1. Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, imagem 1 %32 Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, imagem 2 %32
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: passo 2, imagem 1 %32
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: passo 3, imagem 1 %32 Trek 820 Handlebars Replacement: passo 3, imagem 2 %32
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
  4. Trek 820 Handlebars Replacement: passo 4, imagem 1 %32 Trek 820 Handlebars Replacement: passo 4, imagem 2 %32
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: passo 5, imagem 1 %32
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
Conclusão
Equipe
Cal Poly, Team 1-1, Propen Fall 2012 Membro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
Membros da 5
Autoria de 9 guias
Um comentário
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 52
Duração total: 5,804
