Ir para o conteúdo principal
Traxxas Summit Steering Assembly Servo Replacement
O que você precisa
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: passo 1, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: passo 1, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: passo 1, imagem 3 %32
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: passo 2, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 2, imagem 2 %32
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: passo 3, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 3, imagem 2 %32
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: passo 4, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 4, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 4, imagem 3 %32
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: passo 5, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 5, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 5, imagem 3 %32
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: passo 6, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 6, imagem 2 %32
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: passo 7, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 7, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 7, imagem 3 %32
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: passo 8, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 8, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 8, imagem 3 %32
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: passo 9, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 9, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 9, imagem 3 %32
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: passo 10, imagem 1 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 10, imagem 2 %32 Traxxas Summit Steering Assembly Servo Replacement: passo 10, imagem 3 %32
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 2,271
