Ir para o conteúdo principal
Toyota Corolla 2018 Brake Light Replacement
O que você precisa
  1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: passo 1, imagem 1 %32 Toyota Corolla 2018 Brake Light Replacement, Brake Light: passo 1, imagem 2 %32
    • Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
  2. Toyota Corolla 2018 Brake Light Replacement: passo 2, imagem 1 %32 Toyota Corolla 2018 Brake Light Replacement: passo 2, imagem 2 %32
    • Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
    • The rear turn signal bulb is located at the top and has a grey cap.
    • The brake light is located at the bottom and has an orange cap.
  3. Toyota Corolla 2018 Brake Light Replacement: passo 3, imagem 1 %32 Toyota Corolla 2018 Brake Light Replacement: passo 3, imagem 2 %32
    • Turn the brake light counterclockwise and pull the old light straight out of the socket.
  4. Toyota Corolla 2018 Brake Light Replacement: passo 4, imagem 1 %32
    • Replace the new bulb and push it in the socket.
  5. Toyota Corolla 2018 Brake Light Replacement: passo 5, imagem 1 %32
    • Turn the socket clockwise while placing it in the housing.
  6. Toyota Corolla 2018 Brake Light Replacement: passo 6, imagem 1 %32 Toyota Corolla 2018 Brake Light Replacement: passo 6, imagem 2 %32
    • Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 98
Duração total: 3,722
