Ir para o conteúdo principal
Toy Windmill Repair
O que você precisa
  1. Toy Windmill Repair, Toy Windmill Repair: passo 1, imagem 1 %32
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: passo 2, imagem 1 %32
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: passo 3, imagem 1 %32 Toy Windmill Repair: passo 3, imagem 2 %32
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: passo 4, imagem 1 %32
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: passo 5, imagem 1 %32
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: passo 6, imagem 1 %32 Toy Windmill Repair: passo 6, imagem 2 %32
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
Conclusão
To reassemble your device, follow these instructions in order.
Karim Ladha
Membro desde: 06/27/21
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 328
