Ir para o conteúdo principal
Toy Lightsaber Battery Replacement
O que você precisa
  1. Toy Lightsaber Battery Replacement, Battery: passo 1, imagem 1 %32 Toy Lightsaber Battery Replacement, Battery: passo 1, imagem 2 %32 Toy Lightsaber Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: passo 2, imagem 1 %32 Toy Lightsaber Battery Replacement: passo 2, imagem 2 %32 Toy Lightsaber Battery Replacement: passo 2, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: passo 3, imagem 1 %32 Toy Lightsaber Battery Replacement: passo 3, imagem 2 %32 Toy Lightsaber Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: passo 4, imagem 1 %32 Toy Lightsaber Battery Replacement: passo 4, imagem 2 %32 Toy Lightsaber Battery Replacement: passo 4, imagem 3 %32
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: passo 5, imagem 1 %32 Toy Lightsaber Battery Replacement: passo 5, imagem 2 %32 Toy Lightsaber Battery Replacement: passo 5, imagem 3 %32
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: passo 6, imagem 1 %32 Toy Lightsaber Battery Replacement: passo 6, imagem 2 %32 Toy Lightsaber Battery Replacement: passo 6, imagem 3 %32
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
Conclusão
Uma outra pessoa concluiu este guia.
Zachary Adaes
Membro desde: 03/22/21
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 73
Duração total: 3,784
