Ir para o conteúdo principal
TotalPond Pond Pump Impeller Spindle Replacement
  1. TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: passo 1, imagem 1 %32 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: passo 1, imagem 2 %32 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: passo 1, imagem 3 %32
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Spindle Replacement: passo 2, imagem 1 %32 TotalPond Pond Pump Impeller Spindle Replacement: passo 2, imagem 2 %32 TotalPond Pond Pump Impeller Spindle Replacement: passo 2, imagem 3 %32
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Spindle Replacement: passo 3, imagem 1 %32 TotalPond Pond Pump Impeller Spindle Replacement: passo 3, imagem 2 %32
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
  4. TotalPond Pond Pump Impeller Spindle Replacement: passo 4, imagem 1 %32 TotalPond Pond Pump Impeller Spindle Replacement: passo 4, imagem 2 %32
    • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
  5. TotalPond Pond Pump Impeller Spindle Replacement: passo 5, imagem 1 %32 TotalPond Pond Pump Impeller Spindle Replacement: passo 5, imagem 2 %32
    • Hold the impeller spindle and wiggle it side to side until it detaches from the impeller cover.
Conclusão
Uma outra pessoa concluiu este guia.
Nicole Santana
Membro desde: 01/13/15
612 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-6, Hickman Winter 2015 Membro de USF Tampa, Team 3-6, Hickman Winter 2015
USFT-HICKMAN-W15S3G6
4 Membros
Autoria de 5 guias
1Comentário do guia
The part number of the spindle itself would probably be a good idea to included in this guide.
rz22g - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 1,384
