Ir para o conteúdo principal
TotalPond Pond Pump Impeller Replacement
  1. TotalPond Pond Pump Impeller Replacement, Impeller: passo 1, imagem 1 %32
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Replacement: passo 2, imagem 1 %32
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Replacement: passo 3, imagem 1 %32 TotalPond Pond Pump Impeller Replacement: passo 3, imagem 2 %32
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
  4. TotalPond Pond Pump Impeller Replacement: passo 4, imagem 1 %32 TotalPond Pond Pump Impeller Replacement: passo 4, imagem 2 %32
    • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
Conclusão
Nicole Santana
Membro desde: 01/13/15
612 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-6, Hickman Winter 2015 Membro de USF Tampa, Team 3-6, Hickman Winter 2015
USFT-HICKMAN-W15S3G6
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 3,323
