Introdução
This guide will show you how to open your Thrive. Something that must be done for most repairs.
O que você precisa
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
All of these screws are identical so don't worry about getting them mixed up.
3 outras pessoas executaram este guia.
