Introdução
This guide will show you the steps required to remove your charging port.
O que você precisa
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
All of these screws are identical so don't worry about getting them mixed up.
7 outras pessoas executaram este guia.
Um comentário
I added "better pictures" flag because i was having trouble following the last step cause i couldnt see anything.
