Ir para o conteúdo principal
Toshiba Tecra Z50-A Speakers Replacement
O que você precisa
  1. Toshiba Tecra Z50-A Speakers Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Speakers Replacement: passo 2, imagem 1 %32
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Speakers Replacement, Battery: passo 3, imagem 1 %32
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Speakers Replacement: passo 4, imagem 1 %32
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Speakers Replacement: passo 5, imagem 1 %32
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Speakers Replacement: passo 6, imagem 1 %32
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Speakers Replacement: passo 7, imagem 1 %32
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Speakers Replacement, Hard Drive: passo 8, imagem 1 %32
    • Lift up on the hard drive.
  9. Toshiba Tecra Z50-A Speakers Replacement: passo 9, imagem 1 %32 Toshiba Tecra Z50-A Speakers Replacement: passo 9, imagem 2 %32
    • Pull out the plug from the hard drive.
  10. Toshiba Tecra Z50-A Speakers Replacement, Speakers: passo 10, imagem 1 %32
    • Lift up on the tape holding the bundled speaker wire down.
  11. Toshiba Tecra Z50-A Speakers Replacement: passo 11, imagem 1 %32
    • Pull the bundled wire out of its socket on the motherboard.
  12. Toshiba Tecra Z50-A Speakers Replacement: passo 12, imagem 1 %32 Toshiba Tecra Z50-A Speakers Replacement: passo 12, imagem 2 %32 Toshiba Tecra Z50-A Speakers Replacement: passo 12, imagem 3 %32
    • Lift up on the left speaker with a spudger.
  13. Toshiba Tecra Z50-A Speakers Replacement: passo 13, imagem 1 %32 Toshiba Tecra Z50-A Speakers Replacement: passo 13, imagem 2 %32 Toshiba Tecra Z50-A Speakers Replacement: passo 13, imagem 3 %32
    • Lift up on the right speaker with a spudger and remove both speakers from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Luis Juen Baez
Membro desde: 10/25/21
585 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
Membros da 3
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 19
Duração total: 329
