Introdução
If you’re experiencing a hardware failure or just want an upgrade to your device’s performance, this guide will walk you through the steps of replacing your hard drive.
O que você precisa
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Uma outra pessoa concluiu este guia.
