Introdução
The CPU cooling fan is simple to replace and may need to be removed if the motherboard is replaced.
O que você precisa
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Remove two 3.5 mm screws with a Phillips #0 screwdriver from either side of the fan.
Uma outra pessoa concluiu este guia.
