Ir para o conteúdo principal
Toshiba TECRA R940 Fan Replacement
O que você precisa
  1. Toshiba TECRA R940 Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba TECRA R940 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Fan Replacement: passo 2, imagem 1 %32 Toshiba TECRA R940 Fan Replacement: passo 2, imagem 2 %32
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Fan Replacement, Back Panel: passo 3, imagem 1 %32 Toshiba TECRA R940 Fan Replacement, Back Panel: passo 3, imagem 2 %32
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Fan Replacement: passo 4, imagem 1 %32 Toshiba TECRA R940 Fan Replacement: passo 4, imagem 2 %32
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Fan Replacement: passo 5, imagem 1 %32
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Fan Replacement: passo 6, imagem 1 %32 Toshiba TECRA R940 Fan Replacement: passo 6, imagem 2 %32
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Fan Replacement: passo 7, imagem 1 %32 Toshiba TECRA R940 Fan Replacement: passo 7, imagem 2 %32
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
  8. Toshiba TECRA R940 Fan Replacement, Fan: passo 8, imagem 1 %32
    • Remove two 3.5 mm screws with a Phillips #0 screwdriver from either side of the fan.
  9. Toshiba TECRA R940 Fan Replacement: passo 9, imagem 1 %32
    • Disconnect the fan from its port.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 1,456
