Introdução
There are several access panels that make up the entire back panel of the Toshiba Tecra R940-S9421. You will learn how to replace all of them.
Completing this guide will also show you how to access all of the internal components of the laptop.
O que você precisa
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Uma outra pessoa concluiu este guia.
