Ir para o conteúdo principal
Toshiba TDP-XP2 Fuse Replacement
O que você precisa
  1. Toshiba TDP-XP2 Fuse Replacement, Fuse: passo 1, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement, Fuse: passo 1, imagem 2 %32 Toshiba TDP-XP2 Fuse Replacement, Fuse: passo 1, imagem 3 %32
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fuse Replacement: passo 2, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 2, imagem 2 %32
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fuse Replacement: passo 3, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 3, imagem 2 %32 Toshiba TDP-XP2 Fuse Replacement: passo 3, imagem 3 %32
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fuse Replacement: passo 4, imagem 1 %32
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fuse Replacement: passo 5, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 5, imagem 2 %32 Toshiba TDP-XP2 Fuse Replacement: passo 5, imagem 3 %32
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fuse Replacement: passo 6, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 6, imagem 2 %32
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fuse Replacement: passo 7, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 7, imagem 2 %32 Toshiba TDP-XP2 Fuse Replacement: passo 7, imagem 3 %32
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fuse Replacement: passo 8, imagem 1 %32
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fuse Replacement: passo 9, imagem 1 %32
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fuse Replacement: passo 10, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 10, imagem 2 %32
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fuse Replacement: passo 11, imagem 1 %32 Toshiba TDP-XP2 Fuse Replacement: passo 11, imagem 2 %32
    • Locate the fuse near where the power adapter was.
    • De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
Conclusão
Bryan Underwood
Membro desde: 04/02/18
697 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 334
