Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
Use a spudger to carefully pry up the keyboard screw cover.
Remove the two screws securing the keyboard to the chassis.
Carefully tilt the keyboard towards you and release the ribbon cables.
Use a spudger if needed to release the latch. The latch slides out.
The keyboard is now free and can be set aside.
2 comentários
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
