Ir para o conteúdo principal
Toshiba Satellite e205 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite e205 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: passo 4, imagem 1 %32
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
Conclusão
Tyler
Membro desde: 06/19/12
4.920 Reputação
Autoria de 16 guias
Equipe
TechForce Membro de TechForce
Business
Membros da 2
Autoria de 25 guias
2 comentários
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Responder
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 641
