Introdução
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
O que você precisa
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
2 comentários
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
