Introdução
Remove the bottom cover of the laptop.
O que você precisa
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
Um comentário
Step 11 is missing the step of removing the wire from the white pin just above the nuvoTon chip (black in color) this is located when moving diagonally left from the black wireless antenna lead (green circle) and the top left red circle containing one of the black screws. All descriptions of direction are based on the picture used in step 11.
