Ir para o conteúdo principal
Toshiba Satellite c650d RAM Replacement
O que você precisa
  1. Toshiba Satellite c650d RAM Replacement, Battery: passo 1, imagem 1 %32
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d RAM Replacement: passo 2, imagem 1 %32
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite c650d RAM Replacement: passo 3, imagem 2 %32
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d RAM Replacement, RAM: passo 4, imagem 1 %32
    • Remove the one 5.5mm Philips #0 screw that holds in the central panel.
  5. Toshiba Satellite c650d RAM Replacement: passo 5, imagem 1 %32
    • Pull the back panel off.
  6. Toshiba Satellite c650d RAM Replacement: passo 6, imagem 1 %32
    • Remove the RAM.
    • Carefully undo the clips on either side of the top RAM.
    • Remove the chip by pulling it out of its slot.
    • Repeat until you have removed the chip that you want to replace.
    • This laptop has only two slots for RAM, and both are filled. Plan accordingly if your goal is to increase RAM.
Conclusão
Uma outra pessoa concluiu este guia.
Brenna Callahan
Membro desde: 10/21/15
868 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
3 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Ao todo: 710
