Introdução
If your laptop gets hot and noisy when it is turned on, there may be a problem with the fan. This guide contains instructions for both checking the connection of, and replacing the fan of a Toshiba Satellite C650D computer.
O que você precisa
Unplug the laptop and turn it off.
Flip the laptop upside down.
Locate the battery on the underside of the laptop.
Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
4 outras pessoas executaram este guia.
