Ir para o conteúdo principal
Toshiba Satellite U925T-S2120 RAM Replacement
O que você precisa
  1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: passo 1, imagem 1 %32 Toshiba Satellite U925T-S2120 RAM Replacement, RAM: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the 9 rubber gripper pads on the back panel of the laptop using tweezers.
  2. Toshiba Satellite U925T-S2120 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite U925T-S2120 RAM Replacement: passo 2, imagem 2 %32 Toshiba Satellite U925T-S2120 RAM Replacement: passo 2, imagem 3 %32
    • Unscrew nine 5.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
    • Unscrew two 6.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
  3. Toshiba Satellite U925T-S2120 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite U925T-S2120 RAM Replacement: passo 3, imagem 2 %32
    • Take off the back panel open by sticking the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite U925T-S2120 RAM Replacement: passo 4, imagem 2 %32
    • Gently pinch the RAM with your thumb and pointer finger.
    • Pull the RAM out of the logic board with gentle force.
    • Try to keep the RAM parallel as you pull it out, so that the RAM does not chip.
Conclusão
Andrew Honderich
Membro desde: 03/29/17
364 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S5-G5, Williams Spring 2017 Membro de Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 592
