Introdução
In this guide you will learn how to remove the battery of your Toshiba Satellite U925T-S2120. If your battery is broken, you may need to replace it. Before beginning this guide you should have all tools that are listed.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to remove the nine rubber grip pads on the back panel of the laptop.
4 outras pessoas executaram este guia.
