Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
Use the plastic opening tool to begin removing the keys off of the device.
Lift up the gate on the ZIF socket to release the ribbon.
Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
