Ir para o conteúdo principal
Toshiba Satellite U405D-S2902 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 2, imagem 2 %32
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 4, imagem 2 %32
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
Conclusão
Brandon Kirklen
Membro desde: 01/11/13
311 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 7-8, Maness Winter 2013 Membro de Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 630
