Ir para o conteúdo principal
Toshiba Satellite U405D-S2902 Display Replacement
O que você precisa
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: passo 2, imagem 1 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 2, imagem 2 %32
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: passo 3, imagem 1 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 3, imagem 2 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: passo 4, imagem 1 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 4, imagem 2 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 4, imagem 3 %32
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: passo 5, imagem 1 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 5, imagem 2 %32
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: passo 6, imagem 1 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 6, imagem 2 %32
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: passo 7, imagem 1 %32 Toshiba Satellite U405D-S2902 Display Replacement: passo 7, imagem 2 %32
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
Conclusão
4 outras pessoas executaram este guia.
Brandon Kirklen
Membro desde: 01/11/13
311 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 7-8, Maness Winter 2013 Membro de Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 723
