Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Turn the laptop over.
Slide back the left lock, and you should hear a click when it is successfully locked back in.
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
With the keyboard removed, locate the marked screws.
Remove the marked, 5mm screws using the #1 Phillips Screwdriver.
Carefully lift the fan and heat sink assembly.
Detach the fan power cable from the motherboard with your fingers by squeezing the white plastic connector and wiggling gently from side to side.
There will be a grey goop between the copper heat piping and the back of the processor, (indicated in pink). This is thermal paste and allows heat to flow properly.
4 outras pessoas executaram este guia.
