Ir para o conteúdo principal
Toshiba Satellite S55t-C5225 Speakers Replacement
O que você precisa
  1. Toshiba Satellite S55t-C5225 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 2, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 2, imagem 2 %32
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 3, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 3, imagem 2 %32
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: passo 4, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: passo 4, imagem 2 %32
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 5, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 5, imagem 2 %32
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 6, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 6, imagem 2 %32
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Speakers Replacement, Speakers: passo 7, imagem 1 %32
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 8, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 8, imagem 2 %32
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 9, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 9, imagem 2 %32
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 10, imagem 1 %32 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 10, imagem 2 %32
    • Lift speakers up from their mounted position to remove.
Conclusão
Ali Mortada
Membro desde: 10/21/19
229 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G5, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G5
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 33
Duração total: 1,172
