Ir para o conteúdo principal
Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 2, imagem 2 %32
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 3, imagem 2 %32
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: passo 4, imagem 1 %32 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: passo 4, imagem 2 %32
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 5, imagem 2 %32
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 6, imagem 2 %32
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: passo 7, imagem 1 %32 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: passo 7, imagem 2 %32
    • Carefully slide the optical disk drive to the right to remove from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Costa
Membro desde: 10/21/19
363 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G5, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G5
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 381
