Ir para o conteúdo principal
Toshiba Satellite S55t-A5389 Processor Replacement
O que você precisa
  1. Toshiba Satellite S55t-A5389 Processor Replacement, Battery: passo 1, imagem 1 %32
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Processor Replacement: passo 2, imagem 1 %32
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Processor Replacement: passo 3, imagem 1 %32 Toshiba Satellite S55t-A5389 Processor Replacement: passo 3, imagem 2 %32 Toshiba Satellite S55t-A5389 Processor Replacement: passo 3, imagem 3 %32
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Processor Replacement, Processor Fan: passo 4, imagem 1 %32
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Toshiba Satellite S55t-A5389 Processor Replacement: passo 5, imagem 1 %32
    • Disconnect the fan from the motherboard.
  6. Toshiba Satellite S55t-A5389 Processor Replacement: passo 6, imagem 1 %32
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Toshiba Satellite S55t-A5389 Processor Replacement, Processor: passo 7, imagem 1 %32
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Toshiba Satellite S55t-A5389 Processor Replacement: passo 8, imagem 1 %32
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
Conclusão
3 outras pessoas executaram este guia.
William Mazanec
Membro desde: 01/29/18
1.374 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S5-G6, Passmore Spring 2018 Membro de USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Membros
Autoria de 8 guias
Um comentário
Can i use i7 4940mx cpu on this laptop
Movies Star - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 688
