Introdução
If your optical drive is no longer reading CDs, or not ejecting when the button is pressed, then it may be time to replace it. Be sure to try another CD just to check that it is in fact the optical drive malfunctioning, and not a scratched CD being the issue.
O que você precisa
Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
